Poor Luck or bad judgement?
    Originally posted by modena green View Post
    twas good to see the x5 on track,was surprized you didnt take the trailer off si
    Would have took it down the 0 to 60 but i only hire it, think i've done enough damage this year
    Hefty is the new slim!
    Bald is the new bushy!
    Muddy is defo the new shineeeey! (Copyright Grum 07)
    48's are the new bike carbs !
      Get a nylon alternator tension arm from Gartrac as this stops the shock waves smashing alternator casings . It worked on mine (after i'd broke 6x of the foooookin things ) and use nyloc nuts to hold everything on tight . If the lower 2x bolts at the bottom of the alternator still work loose then drill holes through the bolts and fit "R" clips up against the nuts to stop then getting loose . If any bolts work loose then the alternator will flex and break at high revs .
      Pain in the arse but it will stop the casings from breaking and the alternator from flying off .
        still havent sorted my bonnet from the lakes ,did it go up against the screen
          Gaz I have a nylon top bracket v good advice though prob was caused by a bad bracket casting over half the break was black will put pic up pm using a ka alt will take your advise on the boltspp
          Re new boy, no other damage slowed just before it lifted just snapped the bonnet where it mounts its kevlar and fiberglass very lucky
