My reason for not being on track Sunday afternoon @ Croft !
  • My reason for not being on track Sunday afternoon @ Croft !
    Engine was suffering water being blown out at high revs so kept off the track
    Still managed a run down the 0-60 and a major do-nut after the run
    Now stripped
    Time for a new block methinks
    Sorry to see this, but what's gone wrong there then Dave? I can see the piston looks melted but what has caused this and what damage is there to the block then?
      Piston is fine
      No 4 cylinder had a liner fitted
      The liner has slipped
      This allowed compression to enter the water jacket
      Engine ran fine but kept blowing water out at high revs
        Oh heck, rotten luck Dave.
          Top stuff dave - yb on the way ?
            Be a lot easier !
              2.5 Ranger diesel, loads of torque
                not good dave, lucky it didnt drop further, seen a few bds where the throw of the rod has hit the base of a dropped liner
                  If the top ring had got over the end of the liner, some proper damage would have happened. A lucky escape
                    A lot worse than I had. I split a water at the end of the second session on Sunday morning and spent 2 hours in the ****ing rain changing it.
                      when i looked at liners for mine they said they sat in a recessed groove machined into the block so they couldn't slip or move . What holds yours in place then ?
                        At the moment Fairy dust !
                        Great news though !
                        A friendly local engineer has measured the remaining metal between the jackets and the bore at its thinnest point and can machine a recess into the block deck on No4 cylinder to put a flanged liner back in.
                        So all may not be lost yet.
                          good news the david
                            Ummmmmm Dohnuts!
                            Heard you had trouble with your ring as well this weekend dave
                            Hefty is the new slim!
                            Bald is the new bushy!
                            Muddy is defo the new shineeeey! (Copyright Grum 07)
                            48's are the new bike carbs !
                              Originally posted by cossie si View Post
                              Ummmmmm Dohnuts!
                              Managed my first "safe" fart last night since Sunday night - lol
