Locktight ain't good enough !!!!!
I've swopped all the 3x alternator bolts with extra long bolts and nyloc nuts , then drilled holes through them and fitted "R" clips . Plus a nylon fan belt tension arm to stop the casings breaking . Works a treat and will save you 6x alternators !!!!!
For the starter motor i've got masssive long bolts going right through the bell housing with nyloc nuts on the other side . This stopped about 3x starters a year falling out and exploding on the x-member !!!!!
