took all my downstairs rads out,put it in my place.if your ok with soldering you can make up all the expensive manifold bits.you need ,one pump, one tmv mixing valve, one pipe overheat stat and a temperture gauge. run it at about 40-50degrees.i used danfoss solenoid heads,one for each room, on a home made manifold,with an immersed trv head,then wireless programmable room stats.that way it stays on all the time but you can lower the temp at night.it will need its own supply from the boiler .normally controlled by a two port valve. look up some pics on the computer.you dont need to board it if its in the screed.concrete base,insulation ,15mm hep pipe then screed it.
