my Mundaino TDCI started blowing alot of smoke out when under hardish acceleration
is this the turbo going tits up ? as the engine runs fine and drives normaly the rest of the time at sensible revs, but it does not seem to do it if you just press the go pedal when sat on the drive
ideas please as I know **** all much about Turbo Diesels
cheers
Brian
cheers
Brian
Also try and run a good quality injector cleaner such as "Cataclean"
