top info m8 well done...
RS2000 nosecone
You can get the clips from escort spares.www.fordescortspares.com.I think this guy is on this forum or maybe turbosport seems very good
I'm flabbergasted! (especially after getting on the scales after Xmas!).
All my noses have been fixed with meaty hex-head self tappers screwed into those metal plate type nuts* slipped over the slotted holes in the front plate.
Can someone post a pic of the correct screws to use and their size?
* don't know what their real name is in english - I think they're called "U" Type Spring Nuts.
Cheers ders!
As your pic shows EXACTLY the set up on all my RS2000's I decided to check the microfiche. According to said oracle, the plastic clips are ONLY for the plastic grille on the flat fronts. The RS2000 nosecone has spring nuts just as on your photo and my cars!
Panic over!
There should be spacers between the cone and the slam panel.
Just a medium size washer but the center ones have a extra washer
because of the shape of the cone compared with the slam panel.
Tried to find a picture but cant and mines in bits..
cheeRS Gary.
The pictures on the fiche can be hard to make out some times.
This is a bit clearer...
cheeRS Gary.
