hello
long time since ive had a moment to post on here, well i have finally got time to put my engine for my van on the dyno. here is the spec of it
2.1 pinto, 136mm long rods, short comp accralite pistons ( we are doing these to test them and they are the production spec ones with a 20.63mm gudgeon pin).11.1-1 comp ratio.big valve head.bf63 cam, new std crankshaft fully balanced to motor bike tolerences,OMEX ecu,OMEX loom, 45mm throttle bodies,no dizzy just oil pump drive ,new test sample rs2000 sump,hp/hc oil pump,built by guy turner of GTmotorsport/BURTONPOWER, tested at RACE ENGINE CALIBRATION,
we got it up to 183bhp at 7000rpm and it was ot fully mapped at that point. we expect about 190bhp from it when we tweak it in the van and also take it up to the bf63 cams top level 9000rpm.. i will put the video of the van on the rollers as soon as we get it done(have to do 200 miles first)
guy
guy
. I have race cams in my street car and it still drives nice because of the Omex 600 full engine management . Try a race cam in your engine as it will still drive nice if the mappings done properly .
