You won't get banned on totting up if you can prove loss of job woulod cause hardship, family to support, mortgage to pay etc. You need to take your solicitor , about £275 ,letter from work , bank statements etc Your solicitor will advise you. I was clocked at 100.3 on shap fell, normally an auto ban but proved i needed a licence . Got 6 points and £275 fine. As long as the magistrates see your takeing it seriously, mainly by employing a solicitor you should be ok. Got two mates who were in the same situation on totting up, they both ended up on 13 points with fines. The sucker here is even when your 1st 3 points clear you can't afford another 3 taking you over 12 again! Shame it didn't end up in court before you went, you could have took the ban, probably a month, said you had lost your licence, then gone to work abroad, taking licence with you. Think you get a clean licence when ban completed. This is what my mates business partner did!
Good luck with the job btw!
