Frosty the 13th............
  • Frosty the 13th............
    I had a scare also this evening. Decided to tighten up the sump bolts as per Brett advice Came to the bolts between the sump and the bellhousing and my socket allen key wouldn't fit. Engineer Frost decided to make a tool for the job. Was super chuffed as it worked a treat with the first allen bolt Tightened the second bolt and all was good. Came to remove the tool from the allen bolt and it dropped out of the socket into the bellhousing Loads of finger wiggling and swearing and i still couldn't find it. Took starter off and wiggled some more, nowhere to be found. Got my wiggly magnet out and managed to get it stuck in the flywheel Was not chuffed at this point. Retired into the house for a beer and to kick the cat. ding,ding, round 2. After half an hour of more swearing and wiggling they both finally dropped out Was more than ready to say **** it, cars not going, but hey Everything works out well in the end for the Re Shed.
    something is going on ....scary mate
      did it stop leaking?????
        Dunno, not tried it yet........
          hope so. could make a right mess of the trailor
            BELLEND Have to take it to work tommorrow Will be worrying all morning as where I work is like Iraq
              Is the the cat in question in your sig kev?
                Yep, a real pervert.
                  scrap the ****in heap of shite.
                    can i have your ticket if you dont go
                    glad its sorted btw
                      just a long allen key does it hows the white shed and family holding up? give my cutters to dave if hes going to avo day.
                        thats too easy for kev, he likes the drama
                          here you go kev, kick my cat, he's an easy target
                            thats not a cat! its a bat!
                              its a pity there is nothing to scale him, he's a big fukker
