BDA Manifold
    heard of a similair thing to this called stealth, think the custom mentioned it many years ago.
      http://www.bidnapper.com/
        does it work, be gutted if you missed somthing cos it failed and you were on the ****!!!
          It must work as when i bid at the time i always put a few pence on instead of using whole numbers, e.g say 10.28, i lost the bid to 11.28, the chances of the person placing the same pence as me is pretty slim so yes whatever they use works
            Snipers do work, But if you tell the sniper your max bid is £50 you will still loose the auction if someone bids higher be it a proxy bid or a bid placed in the last few seconds.
            At the end of the auction the biggest bid will win.
            In Waynes case I'd have put my Max bid in with 10 seconds to go, realisticly a second hand BDA manifold must be worth £150 so that's what I would have put as my Max. By the time the man who put £100 in realised he was outbid & tried to place another bid the auction would have ended. Waynes a winner at £102.
            By the way Wayne did you get any systems made of that pattern I borrowed you.???
            Mark....
              there are loads of them out there....i don't use them myself i like to bid as i go
                If someone can get me a pattern I can get a copy made in stainless or mild steel
                  can you do that with all manifolds dave?
                    Not me personally but
                      want to get 1 done in stainless to go withthe rest of the system so thats worth knowing d, cheers.
                        Hi Mark,
                        Its being done as we speek abour £300 approx to make the sytem in mild steel he has allready made me the manifold from another orignal manifold, do you want the oold one back?
                        Missing the snow!!!!
                        • #27
                          Forgot to mention its a guy close to Buckingham called Exhaust by design i would recommend him fo any exhaust's as long as you have a pattern
                          • #28
                            Originally posted by Mr. Escort View Post
                            Hi Mark,
                            Doesn't sound to bad, I think Keith as got someone in eye to make him a system..... he was going to use the system I borrowed you as a pattern, so if you could drop it in when you are in the area.
                            Mark....
                            • #29
                              getting mark in the area might be a lot harder though wayne
