heard of a similair thing to this called stealth, think the custom mentioned it many years ago.
BDA Manifold
It must work as when i bid at the time i always put a few pence on instead of using whole numbers, e.g say 10.28, i lost the bid to 11.28, the chances of the person placing the same pence as me is pretty slim so yes whatever they use worksOriginally posted by LOUIE View Postdoes it work, be gutted if you missed somthing cos it failed and you were on the ****!!!
Snipers do work, But if you tell the sniper your max bid is £50 you will still loose the auction if someone bids higher be it a proxy bid or a bid placed in the last few seconds.
At the end of the auction the biggest bid will win.
In Waynes case I'd have put my Max bid in with 10 seconds to go, realisticly a second hand BDA manifold must be worth £150 so that's what I would have put as my Max. By the time the man who put £100 in realised he was outbid & tried to place another bid the auction would have ended. Waynes a winner at £102.
By the way Wayne did you get any systems made of that pattern I borrowed you.???Mark....
Hi Mark,Originally posted by Mexicomark View PostSnipers do work, But if you tell the sniper your max bid is £50 you will still loose the auction if someone bids higher be it a proxy bid or a bid placed in the last few seconds.
Its being done as we speek abour £300 approx to make the sytem in mild steel he has allready made me the manifold from another orignal manifold, do you want the oold one back?sigpic
Missing the snow!!!!
Doesn't sound to bad, I think Keith as got someone in eye to make him a system..... he was going to use the system I borrowed you as a pattern, so if you could drop it in when you are in the area.Originally posted by Mr. Escort View PostHi Mark,
Mark....
