do i put my cibies on...?
  • do i put my cibies on...?
    i don't know if i want my cibies on or not...?....
    there not on at the mo but the holes are there ready to fit them
    what do you think..?
    70
    cibies on
    0%
    40
    cibies off
    0%
    30
    on,on,on,on,on..cars looking lovley!!!!!!!
      do you think.... i'm not sure
        (ON) Paul
          if you will use them then yes
          if there just for comestic then no
            they will be the new wireless ones
              Off
              Proper rallying is done down the lanes!
                this is my 900'th post so it has to be a good one,............................................fi t the f***ing spots,it will look the nuts!!!!,.........and you know it!!!!!
                  pmsl.....you are right as i always wanted them on from the start but now i don't think i want them on
                    Get them ON !!!!!!!!!!!
                      dont put them on
                      no more holes please
                        Paul, I was in the same predicament. The holes were there already....
                        If the holes were not there, then the answer would be simple...you probably could not bring yourself 'round to drilling them in the first place !
                        So, the holes are there so they can be used. Tim suggests only fit them if they will be wired.....but how often will you use them in the dark?.....in fact, how often at all (dare I say it will be trailered? )
                        There is only one answer we both may agree on here..... ie. ....fit them, don't wire them, then whenever you fancy changing the cars appearance from time to time then do it.
                        Just remember to remove them before the MOT, as all lamps fitted should be in working order.
                        My cars in the VbGarage
                          anyone told Kev
                          put them ON Paul
                            deffo got to put them on paul will look the nuts
                              Originally posted by graham John View Post
                              anyone told Kev
                              put them ON Paul
                              what i was going to say
