Having crashed my car recently i have been doing some research.
Basically i crashed my car in this circumstance.
Front locked under braking in wet, i came off and went back on to stop back locked up and it stepped out into on coming traffic.
SO...
If you have a bias pedal box and ford rear brakes and this happens to you, it will have the same effect.
Basically the ford rear brakes are so shit, the piston takes about 5 times longer to lift off the disc, thus when you stamp on them again they bite as they aint had time to free off.
I aint sure about if you have a servo fitted, but if you don't it will be the same as this.
SO...
