floor paint
  • floor paint
    my mate has painted his floor a few days ago but it still hasnt dryed any ideas why?
    car floor?garage floor?
      if it was the first time he done it on the bare floor then he was ment to do a 50/50 coat mixed with white spirit and then let that dry for 24h then do a coat of the proper paint.
        garage floor, should he of used harderner
          what did he use,body filler lol
            not with that hally just air dry..
              i got some floor paint and i had to use hardner,cannot remember wot it was called,was a while ago!!!!
                blow on it
                  if it was a two two pack floor paint it would have come with a hardner,usally a 500ml to a 5ltr,how old is the floor?
                    last time i used a flame i set my car alight and dad
                      i know its terracotta, but you don't need to dry it with a flame
                        Without seeing it, if it is single pack floor paint it will be an alkyd based material. If it is put on thick it has a slow cure cycle and will have trapped solvent under the coating skin. It will cure eventually but will be soft and mark for upto seven days, longer if it is really thick.
                        Plenty of air movement will help.
                          hally it's the sea air up on the west coast no good for drying floor pent he should know that
                            is it dry yet????????? its only been down a week hally
                              can you use the pent to pent kitchen units
