Could someone pass a tape measure between the edge of one wing rail to the other side , the tip to tip as per pic below with dodgy red line , just want to double check a measurement , in mm
1165 mm here paul, but that in on an RS2 with the front not covered with a wing as on a flat front
That saved me asking the question as I have removed the wing from mine but made the rooky error of not measuring it first.... Not that it was quite right anyway.
The "Tin Worm" has been gorging itself on my wing rails...
I shall put the full resto up in the relevant section when I can
Blob
sigpicBlob
24 Hours in a day, 24 Beers in a case... Coincidence?
Blob
Hi, make sure you resize your pics prior to that, asthe one you posted is massive
