Help - measurement
  • Help - measurement
    Could someone pass a tape measure between the edge of one wing rail to the other side , the tip to tip as per pic below with dodgy red line , just want to double check a measurement , in mm
    1165 mm here paul, but that in on an RS2 with the front not covered with a wing as on a flat front
        many thanks Lee , just 2- 3mm difference on mine so I must have things in the right place
          That saved me asking the question as I have removed the wing from mine but made the rooky error of not measuring it first.... Not that it was quite right anyway.
          The "Tin Worm" has been gorging itself on my wing rails...
          I shall put the full resto up in the relevant section when I can
          Blob
          sigpic Blob
          24 Hours in a day, 24 Beers in a case... Coincidence?
            i wouldnt be taking measurements off lee's car as gospel
              Blob
              Hi, make sure you resize your pics prior to that, asthe one you posted is massive
                An irritating part of photobucket that.. I thought that it was going to be the thumbnail attachment.
                Could try the preview post button in future! A lesson learned!
                B
                sigpic Blob
