little tech tip
  • little tech tip
    looking for a orginal looking windscreen washer pump.
    look at Peugeot parts
    undo screw, slip the connector block out reverse it, refit and replace screw. Took under a minute to do.
    sorted. if you want a 99% looking one, paint the connect block blue. yet to try swapping the blocks from a ford pump.
    good tip that Kel and nice and cheap too
      just painted the connector block a with a black and blue mix of kiddies plastic model paint to get a close shade of the blue plastic block used by Ford.
      Bingo !!!
      looks 100% better than the old black capri one.
        come on pictures of the workmanship ??
          great work and info kel,
          will be judging your pump at nat day
          any idea whereabouts the clear terminal cover on the loom can be sourced for the pump
            here we go.
              Yep, If it's the one I'm thinking off then we stock them at work.
              Taffr should be able to confirm if it is the correct one, as I sent him one to try.
              Ahh, not quite the same , looking at kels pic
              Alan
              www.rscarshows.co.uk
              2006 AUTO GLYM Grand Final, class F (1991-2004) Winner,
              2006 FORD FAIR STANDARD CAR OF THE SHOW
              2006 & 07 & 08 RSOC National Day Standard RS Fiesta Winner,
              2006, 07 & 08 RSOC Expert post class Gold cup winner,
              2007 & 08 OVERALL GOLD CUP WINNER
              Mk2 Custom - 2l Pinto, flat front, 5 speed MT75 box, - NOW SOLD
                Alan
                the one in kels pic alan,
                great work kel
                  nice job
                    ford one
                      Going to look into this tomorrow as I should be able to get these. Part number anyone or exact application please.
                        I've got one ot these on my Mk2 already
                        Connector blocks are readily available too
                        Cheers Rob.
                        www.RWD-Escort.co.uk
                          just bought one from that guy on ebay.....would buy a few more if somebody can get them....
                            I have asked him if there are any more available. If I can get some I'll do a batch with the mods...
                              Count me in for two modded ones deffo! Was on my wants list for a long time now.
