looking for a orginal looking windscreen washer pump.
look at Peugeot parts
undo screw, slip the connector block out reverse it, refit and replace screw. Took under a minute to do.
sorted. if you want a 99% looking one, paint the connect block blue. yet to try swapping the blocks from a ford pump.
, looking at kels pic
