FAO Mogs, Hally, Troll, 191964
    not now I have'nt gra
      cos the postman was knocking at my door at 7.30 this morning with them all
      so after work I psyched myself up and went down the garage with the cutting gear
      so far so good
      EEEeeeek
      a needle file here and there, I intentially used a cutter 2mm under size as they have a tendancy to wander, but I measured with a vernier after the cut and it was witin 0.10mm
      more 'oles
      spare parts
      all done crap pic as I didnt finish till 11.30 this evening
      all in all it's pretty easy fitting them, I translated the German fitting instructions that I'll give out with the locks, the worse part is setting the heights and getting them all adjusted, just takes time
      anyway I'm chuffed and a massive thanks to Brian for sorting them out
      Cheers Glyn
      Cheers Glyn
        looks a good job do mine cause im shitting myself!
          they look superb Glyn, well done nicely done,
          BTW Glyn what screws did you get to fit the retainers ? length/ thread type ?
            Its ok son spence and my self will take care of yours with help from lilly
            Sideways Always
              my ****ing good god you not going anywhere near it! probly lily could do a better job!
                who Lily Allen LOL
                  my brand new little girl called lily!
                    wot a laugh we would have bash!
                      see my reply in noobies section,
                        Paul we could get drunk one sat afternoon round Hallys in the hot tub then when theres nothing left to drink we could have a go at it SONwhat you think of that idea
                        Sideways Always
                        • #27
                          i think you must be drunk now!
                          • #28
                            Shopping list you will need,
                            2 off std pitch M4 x12 2 off for the lock retaining rings
                            2 off M6 x 20 bolts to go in the top of the locking plates
                            2 off large M6 washers for going under the slam panel
                            2 off M6 nylocks for going under the slam panel
                            1 off tube of clear silicon sealant,
                            1 off 24mm hole cutter,
                            1 off 78mm hole cutter
                            1 off 6.5mm Diameter drill
                            1 off touch up stick in body colour for doing inside the cut holes
                            3 off cans of strongbow (this is my particular favourite brand other more intoxicating products are available)
                            some copper grease, some threadlock
                            and a very steady hand
                            hope it helps
                            Cheers Glyn
                            Cheers Glyn
                            • #29
                              the only thing hally needs is a jigsaw!
                              • #30
                                i think you can do them for me paul!
