Do you have to make any modifications to the bodywork to get one of those in? Is it easier to fit then a Zetec engine? What gearbox can you mate up to it?
Most of the conversion parts can be bought from SBD and Yuckspeed. very little if any engine bay modifications needed if you run it distributless. im running a type 9 with a V****l to Ford conversion bell housing. Bolt a set of carbs and an aftermarket ECU and away you go.
