Track car build
  • #46
    Wont be long now Paul
    • #47
      I'm not holding my breath mate
      • #48
        Bet yours is on the road before Andys ,,,
        • #49
          Got some panels to fit in the gaps and some nearly fit ok
          And there goes £30 worth of my new wings
          It nearly looks like a car again
          • #50
            Looking great. What make of arches are they and where did you get them from?
            • #51
              Cheers mate the arches are Ralloy ones but the spoiler came with the shell so not sure on the make to honest All alloy spoilers seem fairly standard across the board tho
              • #52
                Thanks for that. They look a good arch, and the fronts seem slightly wider than the ones on my car. Just a standard Ralloy tarmac arch then?
                • #53
                  The fronts are standard but the rears are Ralloys Tarmac arches +1inch.
                  They fit a lot better than other makes I've done in the past but it does seem to be pot luck with arch fit in general
                  • #54
                    Looking good paul, flying through the build!!
                    • #55
                      Don't know about flying mate
                      • #56
                        You doing well Paul, think I'm getting the bug again!!!
                        • #57
                          Here you go Wayne now I'm getting to my favourite part of a build I'm getting the bug again
                          • #58
                            Oh yeah coming along!! Wonder if ill end up with it?
                            • #59
                              Probably
                              • #60
                                Had a few hours on the engine as I was sick of working on the shell
                                The engine had been rebuilt with a big wing sump but with a standard baffle so after a call to G19 they set about making me a gated baffle to fit my sump and a lovely job they did too
                                And after trimming the lip off the WCXM it all fits like its supposed to be there
                                Thought I better get back on the shell so painted the floor to up my enthusiasm up a bit
