Originally posted by chris chapman
Mk1 fiesta
I know im even letting him do all the welding and paintingOriginally posted by Dobbo63 View PostHe would only be bored with Nowt to do so keep him at it Lewis.
I will have to pop over for a nosey. So make sure kettle is on!!!!
lucky man eh
No problem steve just let us know
CheeRS Lewis
Mk1 Fiesta - A998 EDC
Progress made in the past 2 weeks on the fiesta.....
First we cut off the front panel in order to check for rust and luckily its all good then test fitted the new one
Then we clamped the drivers side wing on
We sanded all the paint off around the arch as the arch had lost shape due to filler and there is also no rust there then started to flat back the rear quarter. The sill is also completely solid too
Ive taken most of the badges off and took the rear lights out
We have took out all the glass and stripped the doors down
CheeRS Lewis
Not updated for a while but we've done quite a lot since i last posted.
My dads fabricated a new inner wing top panel as someone had welded a plate in over the original.
We also decided to put in an inner wing panel on the passenger side so now the old wing has been cut off too
I've now got some genuine supersport alloys thanks to Darren (Pieman01) they do need a refurb but i have used some paint stripper and they seem pretty good
The inner wings now also have Shultz, primer and paint on now
The front panel is now welded on and the wings are lined up ready for welding on which will be the next job
p
CheeRS Lewis
