Hi All
Well I've had RRR for a Year now
which is like an eternity for me
After all the teething problems that I had last year..........
The Diff was very noisy & after numerous attempts to solve the problem inc ditching the Tran X Plate Diff & buying a new Quaife ATB Diff it turns out that it's the Casing
So I purchased another Std RS2000 Casing & Run that for a while & all was well. It's off to Dave's (RS2000Custom) tomorrow to get the ATB Diff taken out of my Original Casing & Swapped into the 'new' casing.
So this will Finally solve the Main Problem
I had loads of problems with the Alternator as well............again not an easy fix as mine has been changed from the Standard V Belt system to a Geared Toothed Belt System. In the End I changed the RS 3 Bolt Bracket for a Gartrac 4 Bolt Item & the Metal Arm to a Nylon Arm which meant I needed a longer Belt. Anyway that's all sorted now, I hope!!
Every time it Rained Water came in through the Corners of the Windscreen. This is now fixed as I bought some of the 'non drying' Mastic & filled the Rubber Seals with it.
My Seat Back collapsed on me just as I arrived at Santa Pod so I had a very uncomfortable drive home
But this was kindly fixed by Brian (WST Custom) on here who did a cracking job & it's been fine ever since
My Gearstick fell apart on the Lakes Tour & I had to drive the last 30 Miles with only 2nd Gear
Luckily when I got back to the Heaves Hotel Escort Tec had some for sale
After I managed to dig as many of the Bits out of the Gate as I could & someone, can't remember who sorry
, threaded it on for me as I really didn't fancy tempting fate & cross threading it, with the mood I was in
, all was OK.
I think the Problems arise from the fact that I'm the 3rd Owner to have the car since Paul built it & for two of them it was really an ornament, so to speak. So with me using it & putting on approx 3000 miles I found a lot of 'running in' teething problems but hopefully these are all sorted now
So RRR's gonna have the most changes done to it since it was built by Paul back in '08. Time to put my stamp on it
Anyway to the Upgrades................
Car on Stands for the Diff Casing removing & taking out the Lowering Blocks, to be replaced by the Superflex Leaf Spring Pads
Type 9 5 Speed Gearbox awaiting a Final Degrease before Painting. This was purchased from Steven F
I've cleaned the Gate & fitted a New Saddle, this was minging lol
That's it for now. I'll post more in the next few days
which is like an eternity for me After all the teething problems that I had last year..........
So I purchased another Std RS2000 Casing & Run that for a while & all was well. It's off to Dave's (RS2000Custom) tomorrow to get the ATB Diff taken out of my Original Casing & Swapped into the 'new' casing.So this will Finally solve the Main Problem
But this was kindly fixed by Brian (WST Custom) on here who did a cracking job & it's been fine ever since My Gearstick fell apart on the Lakes Tour & I had to drive the last 30 Miles with only 2nd Gear
, all was OK.I think the Problems arise from the fact that I'm the 3rd Owner to have the car since Paul built it & for two of them it was really an ornament, so to speak. So with me using it & putting on approx 3000 miles I found a lot of 'running in' teething problems but hopefully these are all sorted now
