Well the project has started, even though after buying the car I promised I wouldn't start it until the new house was built & finished so I wouldn't have to transport it in bits to its new home. I sold our Discovery & the missis was happy if I got $5000 for it so lucky for me I sold it for $8500 & pocketed the difference
(hope she isn't reading this)
Curiosity got the better of me so out came the seats & interior trim. Next a little poke about the rust blisters with a sanding disk (what harm can that do.........)
Before I knew it 2/3s of the passenger side are down to bare metal to remove all the filler in it. Whoever did the filler work was a master in this art but slightly stupid at the same time. The rear 1/4 was filled from a fin coat just after the arch to nearly 5mm thick buy the door shut. A simple adjustment of the lock catch on the door post pulled the door to the correct place & off came all the filler.
Look at the thickness of that........
Will probably change the wing at it has damage to the front. Will see if it will pull out with the slide hammer 1st though.
Some people should not be allowed to weld......!
New inner splash guard required,
Snotty floor patches.
Wouldn't want to trust this to much.......
Interesting seat mounts.
So the parts ordering shall begin.
All in all the shell is in not bad nick compaired to the UK ones its just getting the parts in Western Australia that is the fun part.
