Failing its mot dismally due to excessive corrosion has prompted Alex to have the RS restored.
The engine is curently being rebuilt by specialised engines while we set about removing all the corrosion.
The shell looked rough once stripped but after abeing blasted the full extent of the corrosion became apparent.
Suffering from the usual ineer wing and battery tray rot.
Unfortunatly the corrosion had eaten its way into just about every panel on the car.
Even the suroof carrier has seen beter days.
Blasted and stripped and mounted on the spit the resto can begin, watch this space for more updates or follow the build on my project page http://www.andysautobody.co.uk/mk-3-...es-1-rs-turbo/
