my first mk2
Managed to get the front end mocked up with some standard legs so I can get it sat on its wheels to weld the anti tramp bar brackets on the axle, should have done that before the axle was stripped to blast but hey ho shit happens.
If anything looks wrong please let me no as I've never put a mk2 together and it was bought in a load of bits!!
Also attached the tramp bars to the shell ready for axle going in, think these are on right way?????
Lol to the guard dog!
Was going to fit wings first tony but wanted to make sure I got in all the turret area with the sealer, also decided that if I fit everything up now suspension wise then sit it on the floor to fit the wings should keep the gaps good. Il then strip the suspension send all the bits off for blasting and hopefully put it on spit for the last time to seal the back sides of the wings and give the underside its last coat. That way I'm thinking when I get sick of rubbing filler down I can move onto the easy job of painting all the suspension components etc. that's if it goes to plan!
Well made a bit more progress on the rear end set up this afternoon, decided to make make some spacer collars to centrally locate the lowering blocks on the springs I'm no expert with a lathe but managed ok and I'm quite proud of myself
Also made some to fit axle for lowering block to locate into. All are a nice snug fit so shouldn't be any room for error
Same collar showed on the block here
Also managed to get some shock mount plates (cheers mark) but the threads had been snapped off the end so popped into local stockist for some new material to make a new rod/pin for both sides. Used EN 8 grade steel same as what hydraulic rams are made from nice and strong and welds without turning brittle, turned the ends down to m12 and cut a thread on them then welded into position.
Should be a lot stronger than the original set up and less chance of threaded part snapping in future
Hopefully back on its wheels tommorow first the first time in at least 6 or 7 year could even be more!
That looks the nuts mate, bet your well pleased to be at this stageOriginally posted by 13sport View Post
sigpicSanity is the playground for the unimaginative
