Bit more done to the Darlington dustbin today. Cut the grotty bit out of the bottom of the c pillar, glad i cut as much out as i did as the piece behind was gone as well as the front bit. heres the piece i cut out
Made a repair to the piece behind then made a new piece up and welded in then dressed up
Then thought id give the donor bulkhead a clean up and see how much of it i could use to repair mine with. Did it with wire wheel in grinder, it was very rusty so ended up blasting it.
Turned out to be ok for what i need, the left hand corner ended up a bit like a tea bag tho.
Then gave it a quick coat of zinc primer
Should look a lot nicer than this
