VERY pleased to have finally got hold of this bit. Have had a search on eBay going for a year. Bought one a few months back but it never arrived
This one has the EXACT same part number (not just generically similar). Just need to swap over the Ford and Bosch housing covers and the job's a good 'un
andrew my mk1 had one of them fitted are they hard to find my alternator has a loom that plugs into that box
my mk1 still has one fitted though i think its got yellopw tape round the bottom
Yep! My original one had yellow tape. The Bosch replacement has green. I didn't have any yellow tape to hand today, so sealed it in the meantime with "Bosch Green"! Retrofit to follow!
Rather glad I decided to re-insulate the loom. Discovered this little mischief hiding under the wrapping. What you can't see in the photo is the adjacent cable which was also chafed so that the wires were exposed.
All better now! Spliced joint and heatshrink sleeve for one cable. The other one wasn't too bad, so it got taped up with self-amalgamating tape. (You can see the second exposed cable in the background.)
