andrew your car is stunning mate and its seeing yours,parkies,ruddy's,gaz'z etc that spurred me on to get some done on mine .first class fancy coming back to scotland and finishing mine off
Work has kicked progress in the teeth over the last couple of weeks, but managed to advance a bit over the weekend and am taking the week off to press on.
Gearbox is in after a struggle. The quick-fit solution I used basically didn't work. I followed some info from years ago when I bought the inserts for the bell-houing and M12 cap-head bolts. I can't remember where I got the info from, but it was a reputable source at that time.
It started off when I drilled out the threads in the gearbox eyes and found the bolts were too big for the casting recesses. Out came the lathe from its hibernation and the boltheads were turned down. After some fettling with a Dremel and grinding wheels, I finally got the bolts to fit in from the casing side.
Fitted gearbox under the car and then couldn't get the bolts to align with the threaded inserts in the bell-housing. To cut a long story short, the whole clearance issue was just not panning out. Finally had to admit defeat and take off bell-housing. Mated Gearbox to bell-housing outside of car and used the old cross-member lowering trick to get it all back and fitted. To be honest, even if the bolts had fitted, it would have needed some special tools to get to the upper gearbox bolts. Hats off to peops who have sorted this like Dave and no doubt Kel - I couldn't master it!
Two or three gearbox refits at 30°C were slightly fatiguing to say the least.
Also found that the gaskets I'd bought for the gearbox years ago had shrunk, so had to make up new ones - fortunately having some gasket material to hand!
WIth gearbox and propshaft in, I finished off the fuel line fitting. Can you believe it - after having obtained the correct push-on clips over the rear axle, one of the nipples that you push them on to broke off as I was fitting it! Self tapper rescue team arrived.
Didn't like the floppiness of the fuel line over the rear wheel arch, so introduced a new pipe clip to keep the lines tidy. Suppose car will be "modified" now.
i like that very good work drew, i can now see the spacers used on the propshaft, they are the same as the ones fitted to my car.
I agree the fuel lines do seem floppy but i did use two clips to secure line and it doesnt seem too bad
looking great drew
Managed to get the dash painted today. It's quite a significant milestone, as I can get on with pedal box, steering column, heater etc., which I didn't want to do whilst there was another interior paint-job waiting.
Was surprised when sanding back to discover that the dash is two-tone (satin and matt). After years of armor-all and Auto Glym both sections had taken on the same shimmer. As the paint flaked off, however, it became clear that the part between coaming and windscreen is matt.
Seriously, the coaming is what you call the dash-top. Coaming I know from planes where it is the bit which extends to throw the ****pit instruments into shade making them more easily readable.
Matt / Semi-Matt division is exactly under this dash-top.
