Well 6 years after I started the last Rally Car Rebuild when I swore I would not do another I have bought another car which to be honest is mainly cosmetic and does not involve much welding repair other than outer rear arches and o/s outer sill repair .
The sudden and totally unexpected passing of a very close friend my Rally Mentor and a well known member of the original Yorkshire Rally Mafia prompted me into actually going out and competing again next year ,it will be 23 years since I last drove a car competatively so my expectations are not to high but I'm doing it for the craic and the **** taking as much as anything .
Well some pics before I started and the car spec as bought .
The electrics look are like they were done by David Blunkets dog
More pics when I can get Photobucket to work ,axle is already out , all the interior , windows , fuel tank etc.
Getting a new Ralloy Tank this week and rewired dash ,heated screen etc. , will be finished with a full respray in white with Portugal 1979 Mikkola Blue stripes
Unarched strengthened shell , 6 linked (watts linkage), turreted , Full SD multipoint cage, strut brace , fire wall , front & rear spoilers etc Very straight and honest little car .
Engine
2.0 Litre 16V Ford Zetec engine . Twin 45 Weber's with KN filters,
Weber/Alpha ECU
headwork done, and mild cams,
Retro Ford water rail kit , Cert-met Competition clutch. RWD exh. in heat wrap. A modern Ford engine which goes very well and loads of torque
Transmission
Tran-X 5 speed s/c c/r type 9 box , with single piece propshaft and RS Alloy bell housing. Disc braked rear strengthened axle with 4 link mounting and watts linkage on the rear , GP.4 turret rear shockers fitted with a 4.1 Tran-X LSD unit.
Brakes & Suspension
Bias pedal box, hyd. hand brake , Princess 4 pot front calipers
Drilled, grooved & vented discs.Rear
XR3 calipers &
Vented discs.All lines inside. Bilstein front struts with RTM , WCXM , Quick rack , On car adj. TCA's , Coil over rear shockers with 6 link set up.
Other
Centre fuel tank , twin Facet fuel pumps & filters . Boot mounted battery , Alloy sump guard , Big bore exh system. BDA big header rad with twin elec fans ,
Magnum seats,TRS aircraft release harnesses . Plumbed in & H/held Fire Extinguisher .foot rest,
Polycarbonate windows. Laminated screen
Fiberglass bonnet
Long wheel studs ,
OVERVIEW
This car has been sat in a dry garage and not used for 2 years, Needs small amount of cosmetic TLC but mechanically it is sound and the shell is very good. Could be arched to make clubman GP.4 car as its already 6 linked
Engine
Weber/Alpha ECU
Transmission
Brakes & Suspension
XR3 calipers &
Other
Fiberglass bonnet
Long wheel studs ,
OVERVIEW
