Well 6 years after I started the last Rally Car Rebuild when I swore I would not do another I have bought another car which to be honest is mainly cosmetic and does not involve much welding repair other than outer rear arches and o/s outer sill repair .
The sudden and totally unexpected passing of a very close friend my Rally Mentor and a well known member of the original Yorkshire Rally Mafia prompted me into actually going out and competing again next year ,it will be 23 years since I last drove a car competatively
so my expectations are not to high but I'm doing it for the craic and the **** taking as much as anything .
Well some pics before I started and the car spec as bought .
The electrics look are like they were done by David Blunkets dog
More pics when I can get Photobucket to work ,axle is already out , all the interior , windows , fuel tank etc.
Getting a new Ralloy Tank this week and rewired dash ,heated screen etc. , will be finished with a full respray in white with Portugal 1979 Mikkola Blue stripes
so my expectations are not to high but I'm doing it for the craic and the **** taking as much as anything .Well some pics before I started and the car spec as bought .
Unarched strengthened shell , 6 linked (watts linkage), turreted , Full SD multipoint cage, strut brace , fire wall , front & rear spoilers etc Very straight and honest little car .
Engine
2.0 Litre 16V Ford Zetec engine . Twin 45 Weber's with KN filters,
Weber/Alpha ECU
headwork done, and mild cams,
Retro Ford water rail kit , Cert-met Competition clutch. RWD exh. in heat wrap. A modern Ford engine which goes very well and loads of torque
Transmission
Tran-X 5 speed s/c c/r type 9 box , with single piece propshaft and RS Alloy bell housing. Disc braked rear strengthened axle with 4 link mounting and watts linkage on the rear , GP.4 turret rear shockers fitted with a 4.1 Tran-X LSD unit.
Brakes & Suspension
Bias pedal box, hyd. hand brake , Princess 4 pot front calipers
Drilled, grooved & vented discs.Rear
XR3 calipers &
Vented discs.All lines inside. Bilstein front struts with RTM , WCXM , Quick rack , On car adj. TCA's , Coil over rear shockers with 6 link set up.
Other
Centre fuel tank , twin Facet fuel pumps & filters . Boot mounted battery , Alloy sump guard , Big bore exh system. BDA big header rad with twin elec fans ,
Magnum seats,TRS aircraft release harnesses . Plumbed in & H/held Fire Extinguisher .foot rest,
Polycarbonate windows. Laminated screen
Fiberglass bonnet
Long wheel studs ,
OVERVIEW
This car has been sat in a dry garage and not used for 2 years, Needs small amount of cosmetic TLC but mechanically it is sound and the shell is very good. Could be arched to make clubman GP.4 car as its already 6 linked
Engine
Weber/Alpha ECU
Transmission
Brakes & Suspension
XR3 calipers &
Other
Fiberglass bonnet
Long wheel studs ,
OVERVIEW
,got the axle rebuilt and painted today and hope to have it back in this weekend ,I will take some more pics tomorrow and post them in the next few days .
