48mm Jenvey throttle bodies on a normal DCOE manifold .
) . Adjusted the rod on the cylinder for the front brakes so that it now has 20mm more travel than before . This should get the front brakes clamping alot harder than before .
. Picked up some braided hose and a selection of fittings to plum in the line line lock and sort the brakes out . Fitted the line lock solenoid at the top of the inner "A"post and it fits good . Fitted the on/off switch onto the gear lever then made all the pipes up ready for fitting today .
