It started off as a tidy up the top plates looked a bit iffy,Had a closer look and could see the the wing rails were going so took the plunge and took the wing off
Reason: messed photo up
Going to be a while doing it,it wasnt quite as bad as i was expecting after taking wing off ive seen worse
i think a lot of people who own a classic ford eventually learn to be good welders lol.At least once its sorted you know you got a nice strong car again
Hi guys a quick question,when i was removing the wing,after wire wheeling the paint off to find the spot welds there were some numbers stamped on the flange in between the spot welds is this normal?
Looks like its going to be nice and solid when your finished
Yes its the only way cut any rust out or it will keep sreading,i keep finding bits that need to be cut out but just got to keep going until its all gone should last a few years more then
