ALANS MK1 ESCORT
  • #31
    Can you still get full sets of rubber mats for the MK1s,,,not the aftermarket floor mats only ??
    I think I mean the moulded type
    • #32
      Nice job on the arches, mines still dreaming!! did you blend them in yourself?
      • #33
        Yukspeed fit the arches and MG of york blended them in
        • #34
          What colour is it going to be Alan ?
          My cars in the VbGarage
          • #35
            looking great, now get some paint on it!
            • #36
              who do you work for over in kazakstan alan, thats 3 of us on here!!
              • #37
                Not a lot done recently but a little progress made
                Underside pressure washed and coat of stone cip ans two coats of underseal applied
                Floors cleaned and coat of metal primer
                New dash panel sat in place to see if fit is ok
                New wheels fitted and splash of blue paint before the final choice of colour is made
                Need to start on the interior next
                • #38
                  Worked for TCO / Areva out in Tengiz,,,,,,, Project is now over but looking for something else out there.
                  My wife is Kazak so recent trips back are family visits and Vodka restoc k
                  • #39
                    I was wondering if the Mexico stripes fit ok over the bubble arches ? or does it distort them ??
                    • #40
                      Could do with advice as to the best fuel pump set up for my Zetec running twin 45 webbers
                      Thought of twin pumps in parrellel to actas a back up and move the filter and pressure reg from under the bonnet to the boot
                      Any advice will be welcome
                      • #41
                        My zetec ran 45 webers Alan and ran fine up to 180bhp for 3 years, with a single red top Facet pump in the boot, and i then had a filter king regulator under the bonnet.
                        This will be fine.
                        Part of the Java Green club
                        • #42
                          I guess I will need to repipe the fuel line as it looks like it has been done in copper breke pipe
                          The plan is to run new steel braided pipe through the car so what will be the best bore to use ?
                          • #43
                            • #44
                              wow !!!!
                              Very nice m8 ! Enjoy it!
                              • #45
                                Guess you need to see what fittings you get with pump and regulator and go from there. Id say they will most likely be 8mm
