ALANS MK1 ESCORT
  • #46
    hey
    looking well there m8 .
    keep up the good work
    and more pics.....
    dav
    • #47
      Originally posted by GraemeJ View Post
      Guess you need to see what fittings you get with pump and regulator and go from there. Id say they will most likely be 8mm
      What fuel preasure should I be looking at ?? Will a 7 to 9 psi be ok ??
      • #48
        No!!! you want between 2 and 3 psi for carbs.
        Part of the Java Green club
        • #49
          How about some thing like this ??
          • #51
            Last minute advice before I buy
            • #52
              Either will be fine, but you will need a regulator also
              • #53
                I AM THINKING THE NEXT THING ON THE LIST WILL BE A bda CAM COVER THAT SITS ON TOP OF THE EXISTING zETEC COVER
                Has any on fit this item and has anyone got some pictures ??
                GOT to fix this BLoOdy caP loCK
                • #54
                  No one fit one of these ??
                  • #55
                    yep ive got one!
                    Too old of a cat 🐱 to be f--ked by a kitten
                    • #56
                      Originally posted by alancdavis View Post
                      Could do with advice as to the best fuel pump set up for my Zetec running twin 45 webbers
                      Thought of twin pumps in parrellel to actas a back up and move the filter and pressure reg from under the bonnet to the boot
                      Any advice will be welcome
                      you can use a facet solid state pump they are low pressure and you dont need to use a regulator!
                      • #57
                        Originally posted by hally View Post
                        yep ive got one!
                        Any chance of a photo ????? Please
                        • #58
                          Im still waiting to see a pic of his engine bay
                          Get some foties up hally mate!
                          • #59
                            Have done any thing for ages with being away
                            Time to fit the new window rubbers
                            Glad to find no rust behind the old rubbers
                            • #60
                              I have decided to replace the door rubbers on the car and so I have a question,,,
                              I read some where on here that after fitting the new door seals it has been found that it is difficult to close the door....How can I avoid this ?? and who sells the best replacement seals ??
                              thanks
