And again LOL
  • some nice work there kev
    • Engine is now home safely. Chuffed to bits to say the least. Will be a good motorvator to get the rest done LOL
      Mr Dave Walker (Race Engines) who has given his blood sweat and tears
      Carefully does it.............Nowt like a bit of bondage LOL
      • thats going to be far to fast for you kev
        • Originally posted by richy c View Post
          PMSL, I know Will probably still drive it like miss daisy
          • ,what is the spec of this engine then kev?power/torque etc,i thought the other one was half decent
            • good to see you secure engines more securely than you do RedSheds kev
              • Originally posted by paul andrews View Post
                Dave said with the right carbs should be good for 200bhp.
                205 Block bored to take 93mm Pistons. Standard Crank offset ground to make 2.2 litres, 1.6 Diesel Rods, Full race head with HT1 Cam kit and double valve springs/Ally Spring caps. 12:1 compression ratio. Fully lightened and balanced, Light flywheel and balanced with Helix Clutch kit. H&H Dizzy running Vauxhall Coil. Bike Plug adaptors in head. Torque should be about 170 lbs I think (Again, depending on carbs)
                Other engine was a really good spec but just couldn't resist this one.
                • what carb's you getting ?
                  • ive got an h&h dizzy on mine and lost 10 bhp might put points back on
                    • surely a high powered engine is simply not necessary for driving a car on and off a trailer
                      • Are you getting new off road tyres for the gravel stages?
                        AKA The Dipstick
                        • nice spec m8,you using a hi-torque starter with that comp ratio as well?
                          good GRAVEL spec that
                          • Originally posted by Frosticles View Post
                            you expecting a storm never seen it done like that before
                            • Originally posted by wetandwindy2 View Post
                              LOL wanted to make sure it didn't move
                              • Looks the business Kev!
