lookin good g, best of luck with getting her done - look forward to the pics
X pack freshen up
 It don't need tarting up as it still looks good , just drive it instead . I like your seats sigpic 2.1 ATMO YB POWER . sigpic 2.1 ATMO YB POWER .
 I thought they looked like Moorlands X Pack, they look superb Graeme!Originally posted by grum View Postit kept surprisingly well over the winter in the garage - just carpeted and a cover, may look into a 'carcoon' one day
 the seats are the Scheel type Tim - in '06 i had a set covered in the scheel material (same stuff as the old bmw 3.0 csl etc) just to be different really from the fishnets and rolltops, although the Moorlands X has a set and they look superb - so they just had to be done
 material was sourced and it was a darn lot cheaper that beta i can tell you
 Looks good already Grum
 Missing some 44's and airbox though
 ( you knew I was gonna say that didn't ya )
						cheeRS )
 Ian
 "Live everyday as if it was your last, because one of these days, it will be."
 Jeremy Schwartz.
 "Better to burn out than fade away"
 had a few hours at it today - most of the bits off the block - carbs, exhaust, rad, bulkhead pad and loom is out too the loom seems ok actually - think just the ouside part of the loom seemed to 'crisp up', so should be an easier fix than thought the loom seems ok actually - think just the ouside part of the loom seemed to 'crisp up', so should be an easier fix than thought
 most of the grime is superficial and should clean up well
  , you are at 45 degrees to the rest of the planet
