Head back from Cylinder Head Developments - new valves fitted 1.80" / 45.5mm inlets
Been lapping in the valves again tonight
Off to machine shop in morning for a session on the miller to modify the head to fit the new valve springs (much thanx to Brett Simms Motorsport for the advice)
Many thanks to DJL Engineering - Wednesbury I have been using their spark eroder to make a tool to modify the Pinto spring seats and for letting me loose on his milling machine.
This is to allow "non-Ford" Kent Cams valve spring to be used to eliminate the valve bounce I was suffering at 8000rpm
1st pic is the spark eroder making the tool for 2 days
Then the finished tool and on the miller
The finished modified spring seat ready to begin rebuild (note the step still on the other valve guides prior to removal)
Almost finished tonight and engine should be running Sunday
Hefty is the new slim!
Bald is the new bushy!
Cheese is the new no cheese guarenteed!
Muddy is defo the new shineeeey! (Copyright Grum 07)
Red Escorts are now Capris, thanks midlands Plod!
48's are the new bike carbs !
