ye ive looked into doing the gearbox first, and then doing the engine at a later date, as its a daily driver, and i cant really afford it off the road for too long. is there anything else apart from xmember, bellhousing, and sump that ill need?
from one 1300, to another, engine swap, with pics
Easiest swop is a 1600 crossflow. Exactly the same as your 1300 just 1 inch taller. Everthing else the same except maybe the exhaust manifold. You can even run about in it pretending it's still a 1300 if your totally dishonest, Not that I would condone such actions of course as your insurance would be invalid if you had a bump
Chris
More of Banishit's Handywork!!!
crossflows all well and good, but i want to go something a little bigger, and something a little more modern etc. i dont want to start an arguement about pinto vs crossflow, but personal preference is to go pinto, as i worked at a berakers for a few years, and it was common knowledge that the pinto was one of the most reliable engines ever made.
