looking good will be a stunner when its finished !!!
Li Lo project
Bit of an update. Progress has been a bit slow, it seams to take forever to sort bits out. find them, clean them, paint them, then fit them.
Got the wiring in, it was decided to hide as much of it as poss so the rear loom has gone over the roof and the front loom goes through the wing. Also put the washer bottle under the wing to keep the engine bay tidy.
Got the lights on and the roll cage in. next is brakes hence the question in the teck bit.
some picks hope you like
Cheers Mattsigpic
Originally posted by MK2 - MATT View PostGot the wiring in, it was decided to hide as much of it as poss so the rear loom has gone over the roof and the front loom goes through the wing. Also put the washer bottle under the wing to keep the engine bay tidy.
Cheers Matt
