Here we go ,ive just got back from paintshop to see my little pippin and im well happy to see it taking shape , they tell me it should be in paint by middle of feb
Harrier well under way
best i can do with pics
some more body shop pics
Cheers all, the lads doing the work have been snapping up some pics right from the start .
i will try and post up these when i can, meanwile the story goes with this
silver harrier first reg 15.02.1980 states sport on v5 but harrier in service book .
last change of keeper 1983 and most of service history all hand books and ziebart cert kept.
the old boy i bought it from had the car from 1983 and run it for 5 years then desided to buy is self a new car with pas ,but promised this to his son that was away in the forces ,he never returned and the car stayed in the garage years till it was brought out in 2007 and was'nt realy that bad considering it had been stored for so long .on the rec truck it went back to my workshop and straight on the ramp for the following inspection .
Brakes and clutch on f/wheel seized but engine turned over free and a new battery , fuel system cleaned and oil & filter changed it started up ,the exhaust lasted about 5 mins then fell to bits .
gearbox removed and new clutch fitted
full exhaust system renewed
discs&pads and front calipers renewed
shoes cyls and brake drums renewed
steering rack renewed
then off for mot ( passed )
then i had then desided to carry on with the mk2 mex resto
you know how it is,(one job at once )so it got tucked away once more .
feb 2008 i stripped it ready for the paintshop as it had plenty of imperfections in the paint work and i was well surprized when carpet and sound deadening were out how good it was underneath on floor and inner sills ,good old ziebart it works well ,the underside is rust free too inc brake pipes and im not removing this as i just want a car that i can use .
most of the mec parts have been sent off to be revived and engine stripped and cam & bore wear found
so time to send this of to jem enginnering for a rebuild and overbore
the trim in the car is not to bad ,seats just needed a good clean up and carpet frayed on n/s footwell.
hoping to start rebuilding this next month and i feel a divorse coming on this time judging by the prev resto projects.
