Well as the engine is out I thought I would start fitting the Megajolt system to the RS.
These are the parts you need, you will notice I have cut the dissy in half as you only need the drive for the oil pump.
Thanks to Leon for the spare dissy
First fitted the Trigger Wheel
I got the trigger wheel and VR bracket from www.Trigger-Wheels.com
This is with the VR bracket on
I mounted the EDIS4 unit on the bulk head as I'm fitting the Megajolt ECU in the glove-box.
Thats all I managed today as still need to make up a wire-loom and find a place to fit the coil pack.
If I can get it the engine all back together in time and get it running on the Megajolt before Nat Day then it will be running on the Megajolt system otherwise I will put the engine back together and run it on the Dissy but leaving all the bits in place.
Well post more info as I go
