Thought I'd start a thread on this Forum for my Flat Front RS2000............Bought it quite a while ago.
Decided to roll it out of the garage after it had been sat around without turning a wheel for 12 months or so just to turn it around so I could work on the front suspension
Anyway, it obviously needed some TLC as although it looks fine from a distance the paint had deterioated, so not the best of jobs then !!!!!
Then on further inspection a friend spotted what looked like the start of the dreaded "Tin-Worm".
As luck would have it I dropped into Spellers Accident Repairs only to find the garage working on two RS2000's.........one belonging to Paul Ruddy.
John (Speller) collected the car from my house and has stripped the underside back to metal so it can be coated with a product called Linex.
It's sort of a Spray-On, very tough Rubber that goes on much like you would spray paint on a car...........
I'll post some more pics once the underside if completely stripped (almost there) and when the Linex had been applied.
The RS is then going to be Repainted, same colour (I think).
Thanks.
Thanks.
