been busy the last few weeks in the garage pumped loads of waxoyl inside the chassis,sills,doors etc.fitted the servo & new master cylinder with all new brake pipes.also fitted the wiring loom and heater box.Hopefully fit the engine next weekend.
going together...she's together at last!
Brian why not get the parts powder coated I did it saves so much time & gives a perfect finnish & it's cheap.
The RS is going together with the original & standard engine only covered 38000 miles,4 speed gearbox,gp1 bilsteins legs,alloy roller top mounts,bilstein rears,lowered aprox 1 1/2 inch,a set of date matched 7j ronal 4 spokes,every bush will be renewed with polly bushes and a new genuine Ford exhaust + lots of new nut's & bolts to hold things together 'I find they do help'sigpic
