I took the car into the paint shop to get some minor bits done to the front wings and bonnet before The Lakes Tour as after 28 years the primer was starting to show through under the paint after plenty of polishing
Once in there we noticed a few little bits that needed sorted which has continued to grow by the day and what started out as a couple of days work has now ended up with a full a new scuttle panel fitted (the old one was rusting under the windscreen rubber), repairs to both door sill tops (again where water has collected under the door rubber seals), removal of the black vinyl roof as this was in need of replacement sometime in the next twelve months (I like the car without the BVR and may relace in the winter) and a full outer body respray
Below are the pictures taken so far :
Picture of the car a couple of weeks ago before work started
Starting with the removal of the BVR and the bumpers
Front Nosecone removed. Bodywork is in good condition behind the nosecone (shaky picture )
Replacement Scuttle Panel supplied by Darran and Mark at Escort Tec. Quality replacement as usual from these guys In place to check fitment before final fixing.
Will keep you updated as the job progresses.
 simular stage as mine .....nice car
