pockets's mk1 resto
    i had to go into work today and move the mk1 out so i dont get into sh!t tomorrow morning from the boss, i didnt know fiona had video'd me taking it out.
    here it is if you'd like to see it.
    Store your photos and videos online with secure storage from Photobucket. Available on iOS, Android and desktop. Securely backup your memories and sign up today!
      doh! edited, posted twice for some reason!!
        looks well in the vid, you cant beat the mk1 shape
          i finally managed to drag my a$$ into the garage to do some more work on the old mk1.
          as usual what started off as a little hole about 3 inch square got bigger and bigger
          im getting sick of finding other peoples shady repairs on this car
          can you believe the roll cage and seat belt bolts were mounted to an unwelded inner sill/floor panel and the inner sill to chassis leg was "repaired" with a thin bit of stainless and it was screwed in place then all covered in seam sealer and fibre glass!
          not anymore though, heres some pics
          heres what it might look like one day if i get finished, this is in this months classic ford mag
            Nice 1 David! Love the look of that Daytona yellow mk1 too
            Are you plannin on fabbing slightly bigger rear arches like that 1?....good Idea right enough if your not goin down the narrower axle route
            Look forward to seeing this 1 out and about
              thanks craig, im not doing any bodywork on it im just leaving that part for another day/year so it will be about with rusty spots and bubbles for a while.
              it will just have a set of rs 4's on it to keep things nice and simple.
                Cool mate, gona look smart will be well woth the work
                  small update this is saturdays work
                  i finally got motivated this morning to do some work on the mk1. so after id done todays mot's at work i got onto it.
                  i had to remove the roll cage again after marking the positions to weld in the other 3 roll cage mounting plates and then weld a small ish hole and a crack on the drivers floor.
                  then its was clean up time on the floor inside and out so i could start undersealing and painting.
                  i forgot to take pics of the welding but got some of the floor after its been painted with zinc primer inside.
                  and just as i was tidying up brian came in to make up another tube for his roll cage.
                    i thought since today was such a nice and warm day (for once) id better get my back side into town and paint the inside floor so it will be dry for getting it out the garage in the morning.
                    while painting i realised that id forgotten to re weld the rear seat back/bulkhead panel at the bottom as some one had started to remove it for some reason, that will be the next job.
                      nice work keep it up
                        thats coming on nice
                        • #27
                          getting there, will soon be time to fit some bits back in
                          • #28
                            thanks guys my next jobs are to seal the underside of the floor , brake replacment and electrics as mot much works!
                            • #29
                              i was workin on the mk1 friday night and all day saturday. the motivations come back again since the finishing lines in sight
                              on friday night i built up the roll cage in the garage and gave it a rub with some sand paper before giving it a coat of top quality smootherite in silver just to tidy it up.
                              then i ripped out what was left of the headlining, painted the rear bulkhead/parcial shelf gloss black and masked up the windows and sprayed the roof skin satin black. ANYBODY WANT 2 REAR HEADLINING BAR THINGYS??
                              saturday i had the help of my mate allan ( green boy ) to sort the electrics ( well i was more like his apprentice! ).
                              we had to untape most of the wiring loom in the engine bay as its been bodged to convert from crossflow to pinto with lots of bad conections, exposed cut wires and lots of tape every where else. i knew it wasnt very safe so it was better to get allan in to check it as hes way better and faster with electrics than me.
                              with quite a few wires checked, cut out and replaced things like break lights and indicators are starting to work again and it even runs better! but we still have some wires behind the dash to check as allan found one that was burnt through
                              after allan went home i put on the rear interior 1/4 panels and sat the roll cage in ready for me to bolt it down next week.
                              heres some pics of the weekends work
                              the cage after a quick paint
                              green boy doing his favourite pastime of chopping out wires
                              this is what was removed! :shock:
                              • #30
                                Looking good David, hope Fionas looking after you for all the good work your doing on her car
                                Roll on the Tour 2011
