good to see it progressing glyn, good work there
My mk1 73 Le mans green Mexico
Cheers lads, all seems like ages ago now
then it was up on the highest spit in the worldto have a look underneath
braced the door shut with some angle iron tacked into place and removed the offside sill as it had been fitted too high.
Found a small area that hadn't been welded last time while we were there.
And after a bit of jigling and fettling started to re-fit the new sill in the correct place
lovely bit of angle ironand another new sill in the bin
nice patchwork found behind so that was cut out as welland replaced with nice stuff
door and wing on and off a couple of hundred times and Mark revved up the Mig and tadarr
Originally posted by Tim View Postthink this thread is to try and help glyn remotorvated him self to get it done in time for the lakes
or at least june 21st
wot Tim said (without the lakes/June bit lol) and just in case anyones intersted that didnt follow "progress" in the past
and cos It will carry on this time
Mark then started Melding up the back end
finished the offside lower corner and tankwell off with some repair sections of inner arch, so the outer arch is now joined to something instead of just flapping in the breeze,
