chocolate hob nobs,rolls royce of biscuits,slightly better than custard creams?
X-pack resto.. just started..
Dont eat too many biccies Rich, i must say mark will be pleased with your fabrication skills with the gutter work. hope it blends inOriginally posted by richy cgot the all clear from boss. so should be able to be there on sunday. troll do you have a vice?(bench vice!) if not you need to get one ,try inexcess.ive made up one template for the gutter bit.see you sunday.
Looks like a shopping trip tomorrow, vice, sheet metal, and hobnobs.... thats if I don't end up at TV Centre which I suspect I will :-(Originally posted by grumthis will be the only resto to have a tea and biccy bill that is more than the cost of the panels
Lots of work done today, thanks to Richie.
NSF wing is also now off, old fusebox hole has been welded up, rust from O/S A panel and floor has been cut out, and new metal welded in.
Hopefully tomorrow the rear X-pack will be off, and then the old OS sill can be cut out and a new one welded in, the the rest of the floor can be fixed later.
New album added so use this new link....
http://www.147gta.co.uk/rs/xpack
Mark
Custard creams were the order of the day indeed.. didn't touch the plenium just worked on the A panel and the floor while I preped the other side and took of the other wing remains..Originally posted by Dave1800BDAanother busy day Mark, plenty of work for richie there. custard creams were todays delight were they.
see you got dressed up for one of the photos
did the plenum come off alright in the end,
Will find out about a plenium next week hopefully from Escort Tec... Brett bought round a sill, front panel and Transit battery tray tonight, I think I might put a NS sill on aswell as I don't wanna have to do this again I can tell u.
More work tomorrow, get the rest of the X-pack off..
<M>
Can't say I was looking Gra.......Originally posted by grumare richies balls ok ? looks like he took a weld splatter straight in bollocks there in one of the pics
More pics uploaded, OS rear arch now off, need to get windscreen out and skuttle panle off so I can remove that bloody heater bowl... thats tomorrows job.
M@rk
