This is what I have done today....The turret doesn't fit the inside contour of the arch very well, is this a problem?....I've seen loads like it! I was going to fill in the gap with a slither of sheet metal, is this common or have i fitted them wrong?  I've measured it against the other one which I was told was correct and its pretty much bang on the same. And just ordered those pins...hope it rectifies my door sag problem.
 . Oh yea got those door pins and it has helped the probelm but hasn't made to door fit, which is rather worrying!! I think it probably because I welded the outer sill in too high, I welded it over a lip and I think, now, part of the sill was the lip if you understand me. Any suggestions or do I need to rip that sill off and get another one?
