BDA engine (and car) with a twist
  • #16
    Originally posted by Miniliteman View Post
    Engines with wet sump have a fillercap on camcover, dry sump engines normally have this opening welded shut or don't have it at all.
    Did you see the lowering blocks for the x-member, so that it clears the sump?
    All of my dry sump BD engines had the filler cap - it just wasn't used.
    • #17
      Proflex dampers on rear axle; is that allowed in historics?
      Also lack of Watts-linkage-bars won't help roadholding
      • #18
        Watts Linkage bars are there https://www.ebay.co.uk/itm/Mk2-FORD-...AAAOSw2A9ecgj2
        No rear leaf springs though.
        • #19
          Modern type of coil and the wire for the tempsensor is conventiently wrapped around the HT lead. Lots of self adhesive cable clamps (don't know the proper english word for these) under the bonnet.
          • #20
            To sum up it needs a bit of work ,,,
            • #21
              Originally posted by biz View Post
              Under age driver??
